I have a widget on a certain preset that I want to paste over to another preset, however, the "copy" function does not allow this to happen. Is there a way to copy widgets from one preset to another?
in the main menu select presets -> move selected trigger to preset. However if the trigger is referencing files from its preset directory you currently have to copy them to the new preset directory manually.
Thanks
