Problem with BetterTouchTool on SettApp
I have been using the BetterTouchTool on SettApp, or at least trying to. The version on there isn’t playing well as in it won’t load properly and keeps crashing. Is it worth switching across to the version straight from the website as asking if anyone else has had this problem
which version are you currently on exactly? (the latest build is also available on Setapp but currently only if you have beta updates enabled in the setapp settings)
