Problem to update BetterTouchTool
Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
A clear and concise description of what the bug is. Any bug reports that contain insults against me or my software will be deleted without warning and the user will be blocked (unfortunately this has become necessary to mention here).
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
Additional information (e.g. crase logs, related issues, etc.): Hello,
Forgive me for any failure in my English language proficiency, but I don't think you'll have any difficulties understanding me. :wink:
I don't know why, but I haven't been able to access Check For Regular Updates on BetterTouchTool 6 itself for some time (I don't remember the version in which this started, but I'm using what I think is the last version available: 6.1104 on iMac Intel 27" 2017 - Sequoia 15.8.1 and the problem persists). I explain: every time I try, a sign appears stating: UPDATE ERROR! CANCEL UPDATE. Of course it bothers, but you can live with it since I have the following solution:
You can update via browser, but I need you to inform me if in the list of updates < All current and previous BetterTouchTool releases for download > only the final versions of BTT are available or if there are also the alpha versions and, if this is the case, please guide me how to identify each of them. My intention is to keep the application always up to date, but without installing the alpha type version.
Thank you for your kindness and have a good and productive day at work. :wink:
do you maybe have a firewall active that blocks BTT?
All releases are available via All current and previous BetterTouchTool releases for download
Sorry, I forgot to comment: there is no firewall restriction for BTT. About the updates, so both final versions and alphas are together there, right? In this case, I need to know how to identify them to avoid installing alpha version, unless I actually have to install it. Thank you
I have some information that may be useful to you in this case: when I noticed this failure in the update, I also could not access it via browser with the prefix "https://" and since then I have only been using "www." (example: All current and previous BetterTouchTool releases for download). Usually I have no problems accessing URL with prefix https://. As far as I could find out, this only happens with the folivora link.ai.
