Press fn key to show control strip doesn't work on >= 10.13
Hi. There is such feature in macOS – press fn key to show expanded/ control strip on touch bar. With btt touch bar fully enabled, it was very handy to have access to some standard controls of control strip by pressing fn key. After upgrading from sierra 10.12.x to high sierra 10.13.x it no longer works that way. Pressing fn does nothing when btt touch bar active. Exactly same behaviour on mojave 10.14.
Touch bar
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version:
MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports)
10.13.6 (17G2208)
btt version 2.636
Is it some known behaviour or bug? Missing that feature
