Hi, I am having a lot of problems trying to consolidate all my configurations in one preset. I have reduced to 2 presets (called default and main) but cannot reliably merge them and things are missing in the result. I'll describe what I have tried in case it is of any help:
Merging the 2 presets loses data.
Manually moving everything to one of them but deleting the apparently empty one also removes some functionality.
Exporting the 2 presets, starting anew and reimporting them loses data.
Restoring a backup of the BetterTouchTool folder in Application Support gets all the data back.
My configuration has grown large and it is daunting trying to sort this manually. I'm attaching a link to a working /Users/juan/Library/Application Support/BetterTouchTool zipped folder. In it, pressing F1 opens a floating menu. I use it as a quick test for the merging: if some icons are missing, the merging has gone wrong and data is missing.
//edit: removed link, please send to andreas@folivora.ai
