Just install BTT on my Macbook Air M4 after successfully using it for a month on my M4 Mini. Even after a reboot, it keeps prompting a persistent alway-on-top system dialog: “BetterTouch Tool.app would like to access data from other apps.”
Regardless of whether I “allow” or “don’t allow,” the dialog keeps reappearing. Even quitting BTT won’t make it stop.
I’m on the latest Alpha and have rebooted–which is the only way to make the prompt go away.
- Type of Mac: Macbook Air M4 15”
- macOS version: Tahoe 26.3
- BetterTouchTool version: 6.222
