Hey, it's a bug that's present for a while and is present in the latest up-to-date version of btt - even though minor one, I thought that it's worth reporting
Steps to reproduce:
Restart BTT
Try to use
Paste Items
action -
Note that nothing is happening
Restart BTT once again
Use an action that will show clipboard manager
Try to use
Paste Items
action -
Action now works
Also I'd have a feature request for clipboard manager - I can later move it to separate thread if necessary.
Application called Clipy
provides a clipboard manager similar to this of BTT - but, BTT lacks something that Clippy does have - custom formatter. In clippy, you can define your own function written in JavaScript that will do some stuff on the copied contents and just then return it.
This could be used similarly, meaning:
- BTT User defines an action "paste from clipboard"
- Adds a custom function by some UI created for it
function parse(text) {
return text.replace(/Clipy/g, 'BetterTouchTool');
- User copies text
Clipy has custom parser
- User pastes using defined action and sees
BetterTouchTool has custom parser
I know that perhaps adding JS like interpreter to it may be tricky, but really any way to custom-parse text before pasting would be awesome
Cheers!
