It appears that a gesture sending the Option/Alt+UpArrow keyboard shortcut is not registering correctly when using Parallels on a Windows 7 machine.
From my testing it appears to only register the Option/Alt key.
Open Windows Explorer and navigate several folders in depth. Alt(which is mapped to Option)+UpArrow should move you one level up in the folder hierarchy. But the resulting behavior is that of only hitting the Alt(Option) key.
Strangely, Option/Alt+LeftArrow and Option/Alt+RightArrow works fine. So there's something about the UpArrow?
Trackpad
- Type of Mac: MacbookPro 17" Late 2011
- macOS version: Sierra (10.12.6)
- BetterTouchTool version: 2.427
Tried several workarounds. The gesture is registering, but the key commands aren't received correctly by Windows inside the VM.
