I have a Setapp subscription but the BTT app there is not the latest and its not possible to update yet. This is why I downloaded (today 21 January) the trial version form https://folivora.ai/. It is the last version and I have restarted my computer several times.
Application's menus wont work properly. For example: I put the cursor on Finder (or File or any other menu) in MenuBar and I left click it: first te pointer flickers, then it waits for a while and only then it opens the menu. The same goes with any other app except BetterTouchTool. If I try to access any of BTT's menubar menus the cursor flickers forever and nothing wont open.
Affected input device: Menu Bar only (the widgets and activities are working nicely)
Screenshots The behaviour is not visible on a static image so I made a very short video:
- Type of Mac: macbook pro 16 m1max
- macOS version: 12.1
- BetterTouchTool version: downloaded today (21 January from https://folivora.ai/). Cant really see the number because I can't access the Bettertouchtool menus to check it out). It is the latest because your ExampleNotchBarNew preset works - on my Setapp version of BTT wouldnt work because it was not the latest)
