Hello,
I used to use BTT for the following shortcut in Logic Pro X:
Tip-tap right (1 finger fixed): go to end of selected region (equivalent to ctrl+fn+right arrow)
Tip-tap left (1 finger fixed): go to start of selected region (equivalent to ctrl+fn+left arrow)
But it no longer works in Logic Pro X for years.
Any tip to make it work back again?
Thanks,
Jonathan.
- Type of Mac: MacBook Pro 16" 2019, Intel Core i9 8 cores, 16GB RAM
- macOS version: Ventura 13.0.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") : 3.553 (1693)
