I have a macbook pro fairly new maybe 3 years old and want to program my function keys on a wireless keyboard that has function keys F13 to F19. My first try was to just add "command shift 4" to F19 I am able to do the first 2 steps but do not see how I can finish the workflow. I can add the commands then I can select the "key" (F19) but it never starts to work, help please! Sorry I am not very technical I know this is probably really easy for most.... Thanks in advance
mh these should behave like any other shortcut, so basically record them and assign an action Keyboard Shortcut Triggers · GitBook
can you maybe post a screenshot of how you tried to configure them?
