TipTap Left (2 fingers fixed AND 1 finger fixed), Swipe from right and I guess many more gestures are not working to activate snap areas. Also, my snap areas are reset after a system restart. I already tried to reset the settings to default which didnt work for me…
How can I completely uninstall BetterTouchTool? I wanna try to completely uninstall in order to reinstall and configure from scratch. Is there any other solution I might try?
Internal + external Trackpad (1st gen)
- Type of Mac: MacBook Pro late 2013
- macOS version: 10.14.6
- BetterTouchTool version: 2.851 (1131) (My License isnt eligible for Updates)
