Type of Mac: MBP Retina
macOS version: Latest HS
BetterTouchTool version: 2.717
I have 2.724 alpha installed now. I restarted my mac. Even took a new preset and making sure i trigegr the command through Hud-Display. The command is being triggered but the Menubar-Items from (File, Edit, View) etc. are not being hidden like before. This problem occured after I run the command (Show/Hide Menubar Items left of BTT) for the first time yesterday with a trackpad gesture. After running this command the "Hide Menubar Items Temporarily" wouldnt work anymore. (I also installed "Vanilla for Mac" yesterday, but I deinstalled it already.) I am sad, because I highly used this function to see all of my Menubar-Widgets really fast. Do you have other suggestions? Thank you!
Ahh thanks, that code means "incompatible system version". Probably something caused it to only work on Mojave. I'll look into that. (And I highly recommend upgrading to Mojave, as there are some super bad security issues in older macOS versions :-))
I am using OSX High Sierra (10.13.6).
Yes thank you! is there a link for the Version before 2.717 meanwhile? Because before it worked. Thank you! But I am always a late adopter with OSX Software. I always update after nearly 10 months after it has been released to prevent system failures etc. Thank you!
works totally fine with the "Hide Menubar Items" on the latest High Sierra. So the problem must occure in the versions afterwards (i definetly had a problem with 2.710 as well: So it is a version between 2.701 - 2.710). Thank you very much!!
