When I use the "send shortcut to specific app" shortcut, which also has "bring window to front" enabled, it does not bring the app (Safari) to the front, and does not launch a new window of Safari, but instead tries to launch a new window of whichever application is in focus now.
keyboard and trackpad
Type of Mac: MacBook Pro M1 Pro 14 inch 2021
macOS version: Monterey 12.6
BetterTouchTool version: (please post the exact version - not just "the latest one") 3.913 (2075)
For example, Safari will already be open, but not in focus, buried under other windows.
Then, I use the shortcut to bring up Safari to open a new window.
But instead of bringing up Safari, it just sends Command-N to the application that I have open.
By the way: you should not use the old UI anymore for any setup work (view only should be OK). It can corrupt settings as it hasn't been touched since 2017 and is not aware of any of the new settings etc..
