Create a touchbar group within a group. Can't open it to edit it: double-clicking will bring you to widget type selection, and using the menu item OPEN GROUP will show a sliding animation but won't work.
Touch Bar
- Type of Mac: MacBook Pro 16"
- macOS version: 10.15.5
- BetterTouchTool version: 3.389
