Need to press "Apply all settings now" ever 10-60 minutes
My mouse config seems to be resetting randomly, need to press Apply all settings now constantly. Afaik I have nothing else installed that could be interfering with this.
You'd need to provide some more information
  • what kind of mouse are you using?
  • Which settings are you noticing being reset?
  • Is your mouse connected via Bluetooth or USB Receiver?
  • Which version of BTT and macOS are you on?
In general settings could only be reset if the mouse looses connection (or if some other app like Logi Options overrides them)
I have deleted every logi app I had before setting up BTT
