Everything related to the GoldenChaos preset
Hello, Im using a MacBook 16 512 version.
so I think I have done something wrong with the installation of GCBTT .. I've got icons overlapping at start up. How do I remove it and reinstall? I can't find a 'Remove' button. The App keeps crashing and restarting also when I'm in the Preferences section of GC.
.. Is there an In depth tutorial that will teach me how to set everything up to my liking? As in .. how is it used in conjunction with BTT. I have a Magic Mouse.. Does it connect to that?
I need the lock screen button to appear instead of 'Siri' but now it's showing only when I press the Control button.
Thank you for any help!
D
