Hi all
i saw there is an option to create custom slider widgets, yet have close to zero coding skills and need some help ;D
i have 2 buttons currently to lower the volume in an music app i use (Jriver media center):
https://yabb.jriver.com/interact/index.php
the way i control the app is via http calls using these commands in BTT currently via the execute terminal commands
/usr/local/bin/wget http://localhost:52199/MCWS/v1/Playback/Volume\?Level\=0.05\&Relative\=1 -O /dev/null
and
/usr/local/bin/wget http://localhost:52199/MCWS/v1/Playback/Volume\?Level\=-0.05\&Relative\=1 -O /dev/null
can these 2 commands can be used in a custom slider to lower/raise the mediacenter app volume?
thx a lot ion advance all, really appreciate any help with this
Z
