I'm using 2 Named Triggers in chain and the first one is executed properly but the second one is never.
I added Show HUD at the end of the first trigger and its displayed properly.
I added Show HUD In the Key sequence just before the second trigger and this is not displayed.
This show that the first trigger finished and it stop here.
As per screen shot the first trigger that is executed search for an image and do a click and then display the Show UD overlay with test2.
This works perfectly and test2 is displayed
Second trigger is more complex but I tested it alone and it works.
I also tested the first trigger and after to add a show UD it doesnt work see screenshot tada shoulb be displayed but its not
