My menubar icon for BTT has disappeared
I've always shown the menu bar icon, and I haven't used or tried any new menu bar features, I don't use any menu bar managers etc. But in the last update or two my menubar icon has disappeared:
I did try to enter some value into this new field last week:
But saw no effect so deleted the text, but I wonder if somehow a bad name for the SF icon has got stuck in the prefs but isn't visible to the UI? where should I look to see if this is some prefs issue?
UI
  • Type of Mac: M2 Air
  • macOS version: 14.5
  • BetterTouchTool version: 4.621
if you have used the recent alphas, possibly check whether it shows up in the "Move Menu Bar Status Item To New Position" action:
Maybe it got moved to an invisible area for some reason. In that case best move it back to one of your visible items.
Just FYI. Hope the next Alpha will fix it.
BTT Version 4.621 (46210)
macOS 14.5 (23F79)
No "Move Menu Bar Status Item To New Position" action exists. However, some menu bar icons, including BTT, are missing. It seems the visible length of the menubar is truncated.
Close BTT, all disappeared icons are back.
All icons on the menu bar are back in Alpha 4.622
Update to 4.622 also fixed menubar icon for me too, thanks @Andreas_Hegenberg !
