Hello, I use the function "Move the window to next monitor" pretty often. Is it possible to also integrate the function to move the monitor to the "left or right monitor"? Right now I have 4 Monitors and when the I enable the function I need to enable it many times, because the window only moves to the right monitor, but not to the left. A fix would be great, thank you!
Update 2021-04: Hello is there any fix for this? Thanks!
