Hi.
Just got BetterTouchTool tonight and It was working great for an hour or two, then certain commands stopped working. I was installing things and messing around with settings but I've tried my best to undo whatever was done. I fully updated, restarted my computer, restarted the app, and even remade the commands. I'm on an M1 mac with Ventura.
The main one that stopped working was the Action to "Move Window to the Next Monitor". Its literally just that set up with the Shortcut
Command `
I've also thought their might be a permissions problem or a conflicting keyboard command already in keyboard settings, but I haven't had any luck. I've also tried using a different command for the same action but that also doesn't work. Would appreciate any help, thanks
