Move window to next monitor don't work with hotkeys
  • Type of Mac: Macbook pro 13, 2018
  • macOS version: Big sur
  • BetterTouchTool version: 3.510 alpha
Moving full size window/half size window (chrome) to next monitor will resize the window without moving it. The resized window will cover most part of the screen,The resized window will have some parts outside the screen area. The window doesn't move to next screen unless I resize ot to smaller size and then use the hotkeys move to next monitor.
neither the shortcut to move window to the next monitor is working.
  • to center
  • to next monitor
  • max to next monitor
    none of them is working
behavior:
animation of moving window is there shortly after hitting the shortcut, but after releasing the keys the window is back to its original position.
thanks for fixing
masos 11.4,
m1 macbook air
