Move Window Left and Move Window Right
I noticed that Move Window Left and Move Window Right seem to move the window to the corresponding side but also put them in the corner. Is this expected? And if it is, is there a way to only move the window all the way to one edge? It doesn't look like a Custom Move will work because it doesn't have center leading and center trailing as an option.
BTT Version 4.215 (2436)
Mac: 13" M1 MBP 2020
macOS: 13.4 (22F66)
Thanks for reading and any help would be much appreciated! :blush:
-Josh
Ah the problem is, I have done some experimenting in the latest alpha's renaming the custom move/resize stuff to make it more clear, but I'm now noticing this doesn't work.
I'm currently working on a new move action that will work like the floating menu positioning, as I think that's way more clear.
You can achieve what you want like this:
Move to left edge
Move to right edge
The "Move the window's" xxx "to the" xxx, are not labeled correctly right now. It should be more something like "Assume the window's xxx" is moved to the "xxx". They only actually update the x/y when the checkboxes are checked.
Ohh gotchya! Thanks so much for the help @Andreas_Hegenberg - this works beautifully
