I am able to confirm move mouse to a position is working in other situations, however, when any of the text relative conditions (relative to text cursor/text selection) is selected, the mouse does not move at all. This is replicated for multiple apps including MS Word, Safari, Finder, and TextEdit.
I have a similar issue. the mouse cursor automatically moves to the bottom left corner of the screen unless I have text highlighted. when text is highlighted the mouse is moved to that area perfectly.
as a workaround I set a series of keyboard shortcuts to highlight the text where the cursor is and then move the mouse there so it works for now but its not ideal.
Type of Mac: MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)
