Space switching always applies to the screen that the mouse pointer is on. To switch spaces in a multi-monitor setup, I need a way to move the pointer to the other screen. It would be great if I could cycle through the screens using a shortcut (not just the main screen).
That'd be cool indeed!
Been trying to look for a solution to this. Currently I just use the "Move mouse to position" feature but since I connect to different screens with different resolutions it doesn't always land on the correct screen I want.
