Move mouse cursor to next monitor
Hey there Frank. Very nice of you to chime in. Sadly, I do not know how to set up a cycle action. I used to be quite tech savvy, when younger and pre-stroke, but have lost a lot of prior savvy. :frowning: Might you have a link to study how to do that? Thank you! Profile - Frank1 - BetterTouchTool Community
Have a look here:
thank you Andreas.
works wondefully
Hey Everyone,
I have a different solution that does not use scripts. I have a 3 monitor setup: My M1 Macbook air screen, a 22 inch monitor and an old iPad air 1 as the third.
What I did was use the “move mouse to position” trigger/action. I set this up with a shortcut key for each screen. I did have to use the “Global position (origin top left corner of main monitor)” anchor point and “absolute pixels” to get it to the middle of each monitor.
I have a static setup at home so this works for me. I would imagine you can do one for work the same way.
To rotate it as per the OP, I experimented with using a simple trigger sequence with a delay and it worked. Only thing I did not do was to add a way to terminate it, but I know from @Andreas_Hegenberg ‘s tutorial, you can add “end after x time” and so on.
Thinking that this approach may be alternative to those who struggle with scripts.
One caveat, if you project to a TV or another screen, it changes which screen the shortcut works on. I am not sure how to make the trigger specific to set screen (unless we use a script maybe - lol).
Will add some pics/screenshots to my post in case that helps.
