Hello,
It would be great if there is an option for "Move Mouse Away From Right(Left) Screen Edge" in the Named & other triggers.
Can you add this function for the next version?
Thanks,
Arsene
Hello,
Thanks,
Arsene
You can use the predefined action "move mouse to position" to do that.
Thanks Andreas,
Where the option is available? in Normal Mouse or Named & other triggers?
Actually, I would like to use the mouse position as a trigger for run a shell script.
So I think I need to it in the Named & other triggers, right? But there is no option like "move mouse to position" in the Named & other triggers. How can I do that?
Thanks
