Perhaps this can be done already, but I'd like to quickly move mission control windows to another monitor, move my mouse to it, and activate the application under it. Essentially, this would be a much cleaner way of moving an active program to another monitor (especially if it's full screen).
I have a sort of work around by moving application to other monitor, enter full screen if it can, move mouse to the position, but this is a bit hacky and often doesn't work. Simply moving a mission control window would be better just like you can do by dragging the windows when in Mission Control!
unfortunately for full screen windows there are no API's available to move them around as far as I know.
For normal windows BTT can do this, but for full screen there are only workarounds like the one you described.
