Move and Resize Window gets stuck with certain applications
When using the Move Window shortcut (modifiers set to Ctrl, Opt, Cmd) and Resize Windows (Ctrl, Opt) certain applications will be stuck in a move or resizing state after releasing the modifier keys.
Unity (https://unity.com/) is a consistent reproduce-able case.
MacBook trackpad, MacBook mouse.
  • Type of Mac: MacBook Pro (16-inch, 2021)
  • macOS version: 12.4 (21F79)
  • BetterTouchTool version: BetterSnapTool 1.9.5
