I've tried to setup my magic mouse and my trackpad but most of the triggers or actions are ineffective. For example as you can see on the screenshot I would like to register only one action first.
If I select 2 finger tap -> middle click then it works.
If I select 2 finger click -> right click then it also works.
If I select 2 finger click -> middle click then just a simple left click happens.
And I face similar issues whatever I want to achieve. I'm unable to build a proper setup because more than half of the combinations are broken.
- Type of Mac: MacBook Pro 15 2016
- macOS version: 10.14.3
- BetterTouchTool version: 2.717
