how to use apple sciprts get AirPods Pro battery ?
This currently works:
use scripting additions
use framework "Foundation"
getAirPodsProBatteryLevel("Dirks AirPods Pro") -- change with your device name
--> {BatteryCase:"86 %", BatteryLeft:"90 %", BatteryRight:"90 %"}
on getAirPodsProBatteryLevel(deviceName)
set xmlData to do shell script "system_profiler SPBluetoothDataType -xml"
set theData to ((current application's NSString's stringWithString:xmlData)'s dataUsingEncoding:(current application's NSUTF8StringEncoding))
set infoDict to (current application's NSPropertyListSerialization's propertyListWithData:theData options:0 format:(missing value) |error|:(missing value))
set devlist to ((infoDict's firstObject()'s valueForKey:"_items")'s firstObject()'s valueForKey:"device_connected")
if devlist ≠ missing value then
repeat with j from 0 to (count of (devlist as list)) - 1
if (devlist's objectAtIndex:j)'s allKeys()'s firstObject() as text = deviceName then
set devDic to ((devlist's objectAtIndex:j)'s valueForKey:deviceName)
set BatteryCase to (devDic's valueForKey:"device_batteryLevelCase") as string
set BatteryLeft to (devDic's valueForKey:"device_batteryLevelLeft") as string
set BatteryRight to (devDic's valueForKey:"device_batteryLevelRight") as string
return {BatteryCase:BatteryCase, BatteryLeft:BatteryLeft, BatteryRight:BatteryRight}
end if
end repeat
end if
end getAirPodsProBatteryLevel
Thank you for sharing the script
I am getting error, any advise Cheers
Error → Expected “given”, “with”, “without”, other parameter name, etc. but found “:”
Line →
Strange. Have you installed the latest macOS (12.3.1) update?
Apple has changed this with version 12.3. It works for me:
What happens if you run "system_profiler SPBluetoothDataType -xml" in the terminal? Are you getting anything back like this (PropertyList-1.0.dtd)?
Edit:
You may need to use the following within BTT, as AppleScriptObjC is used:
BatteryLevel's getAirPodsProBatteryLevel("Dirks AirPods Pro")
script BatteryLevel
end if
end repeat
end if
end script
Hi Dirk
Thank you for replying
I am on 12.2.1
The script fails to compose on the script editor & BTT. it fails to compose at line
I tried to modify it, it compiles, reads the xml, but fails to output the battery levels
set infoDict to (current application's NSPropertyListSerialization's propertyListWithData:theData options:0 |format|:(missing value) |error|:(missing value))
Thank you for looking at it
Apple has changed the XML with macOS 12.3. Under 12.2.1, it can therefore not work.
Edit:
For 12.2.1 you can try to change the following line:
to:
set devlist to ((infoDict's valueForKey:"_items")'s firstObject()'s firstObject()'s valueForKey:"devices_list")
Maybe it works. Otherwise I can't help you, since I don't have macOS 12.2.x.
Tx Dirk
updating to 12.3.1, the script works
Thank you
