There is no distinction between left and right modifiers for the Touch and Notch Bar. Is that correct? And is that perhaps planned? Or is there any workaround? Thanks!
I allow myself to ask this question again. Is there a way to distinguish between left and right modifiers that I am missing?
I currently don't have a definite answer. Differentiating the left and right is a bit complicated (because all the macOS API's do not differentiate) and I need to check whether this can be done in a performant way (for shortcuts it's not a problem because it's evaluate only when you press all the keys, but for these modifiers it needs to be very performant to not cause issues).
I'll update you as soon as I know whether this can be done.
Ok, thanks a lot!
