Missing option to "pin" audio output devices
Last release/beta notes:
"Predefined actions for setting audio output/input device now have an option to "pin" that device"
The option to pin the audio device is only available for input devices, but it is missing in the output devices.
Running BTT 6.753 and macOS 15.7.9
you are right the option was still hidden for output devices, it should now be visible in 6.754
