Mirror Magic Trackpad for upside-down works incorrectly
Note:
Already upgraded to BetterTouchTool v4.363
Hi there, I've just bought BetterTouchTool lifetime license just for the Mirror Magic Trackpad, but unfortunately it doesn't work correctly :(, I hope it's a little bug and it could be resolved easily. Thanks!
I'm using the Magic Trackpad 2, upside down mode. When I turned on the "Mirror complete Magic Trackpad orientation for "upside-down" usage" option, it does reverse the X-axis movement (left/right), however, it also does reverse the Y-axis movement (up/down) - it's incorrect, because when I put the track pad in upside-down, I would expect only the X-axis got reversed, the Y-axis already works well.
If it's possible please make this option to become 2 seperated options: Mirror X-axis and Mirror Y-axis, or please just not mirror the Y-axis. Thank you!!
Apple Magic Trackpad 2
N/A
  • Type of Mac: Mac Studio 2023
  • macOS version: Sonoma 14.2.1
  • BetterTouchTool version: v4.363
