Minimum distance on corner edge is constantly reset to zero
The bug:
I'm trying to use a Move Mouse to Top Right Corner trigger, and I would like to use the Minimum distance from edge before triggering parameter, say at around 200px.
Every time I set up the value for that distance, then click the Save button above, the value is reset to zero. The trigger itself works, but only when I touch the exact corner.
Extra details
At first I thought it had something to do with my OS's locale which uses commas as decimal separator, since the values shown when I changed the distance parameter were shown with commas — I though maybe that isn't saved properly due to numbering format. But since then I changed the way my OS represents numbers, restarted the whole system, and no change of behavior — except that the distance value is now shown with a dot and not a comma when I change it.
Before clicking Save:
Immediately after:
  • Type of Mac: MacBookPro 14", M2 Pro
  • macOS version: Ventura 13.4
  • BetterTouchTool version: 5.072
