Fixed it
I deleted the preset, restarted the app and the downloaded the JSON and imported it manually. Then it was asking permission for the apps and now it is working! Thanks
That's great to hear!
Hey man, great preset! I really do love it. I'm wondering, have you thought of creating a BTT Button to launch the Messages app, similar to how you created the Notes and Finder ones? I would LOVE to see that!
Hey there! I'm really enjoying your preset, but the play/pause button isn't working for me. Any ideas why? When I tap the Spotify song name, it switches to the next song just fine.
I would add that feature (toggle-able) in the next update! BTT is starting to get stable now so will post a new update real soon
Hey there! Are you on the latest version? I tried downloading the Minimalist preset and the play/pause works fine on my end. Perhaps the new update (coming soon) can fix that!
Yea, I'm on the latest version. When I play/pause on Spotify, the icon changes as well, but pressing pause on the Touch Bar doesn't react. It doesn't launch Spotify either. It's no biggie, I can wait for the next update.
- when I press and hold the Option key, the macOS System Preferences are opened and closed.
- Cmd + Z (undo) does not work when this preset is running.
I'm using Minimalist v2.2 | Upload Date: 2018-06-01
cheers
Hi there, this has got to do with the True Tone toggle icon. I will be removing this feature on v2.3 since it constantly triggers System Prefs. But when the community finds a way to fix the True Tone toggle issue, I will update the preset again.
Cheers!
HEY EVERYONE!
New version v2.3 is out!!
Hopefully this version addresses some of the problems you guys are facing! And I've also added support and stablised certain features such as True Tone.
Do let me know if there's anything you want to know, thanks again for the support!
Hi tmxgkh : great job thank you, it helps me very much. How do you get macOs 's icons like volume down or mute ? I didn't find then on the net. Thanks for any help.
David
Hey, love the preset it's definitely my favorite, even over what I've created personally. I can't get the gesture controls to work, though. I removed the 4 finger gestures, and changed the 2 finger gestures to keyboard illumination. None of the gestures work though (3 and 2 finger). Any suggestions?
edit: I just deleted and re-added the gestures
Great to know you're loving it!
Hi tmxgkh this is exactly what I was looking for : thank you very much !
David
Hey tmxgkh!
First of all - thank you very much for the preset, for me it's the best base I've found here.
Though, I've got a question relating the itunes "currently playing track" widget - is there a chance to code so it has an option to switch to next track? I'm pretty much sure you know how to do it
Or maybe anybody is able to help me out?
Thank you in advance!
Best,
Roman
Hey @Ro_your_bro, I'm not exactly sure if this is what you mean. But you could try switching the Predefined Action to Next.
See if this solves your issue, and let me know!
Yes, bro, that's exactly what I need (turned out to be so simple, lol), BUT, I need "Play/pause" button as well. So, perfectly, it would be like if a long tap runs "Next" button and a simple tap runs "Play/pause" as it is now. Is there a chance to code something like this?
Tried to make this but it's not working
Hey @Ro_your_bro, this preset should have already included the Play button which looks like this:
Just to check if the new update of BTT might have wonked out some the presets, check to see if the settings of the Now Playing Widget has the same settings as mine:
