Midi > click and drag command
I want to be able to hit my sustain pedal and for that to perform a click and drag. When I lift my foot I want to it end. Pedal down = on.....pedal up = off
Can this be done?
does the BTT midi event viewer show these pedal down / up events?
yes it does thanks for reply
What kind of events do show up, can you post a screenshot?
theres down on the pedal in first shot,
and up on pedal in second shot
You could try the attached setup. It requires the latest BTT alpha version (3.368)
midi-test.bttpreset (4.4 KB)
sorry I couldnt find that version on the site, could you provide a download link? I use catalina hope thats ok
You can get it by clicking the menubar icon and clicking "Check for alpha version updates"
it works! thank you very much andreas
Nice!
