Hi all,
I'm new to the app and I've been tinkering with the config to try to achieve mouse-only window move with middle-click.
I got the window move part figured out but at the expense of my middle-click default behavior.
Is it possible to achieve such config that a simple click (eg. open link in new tab, close tab on browser) can be kept with the default behavior, while holding/dragging it will allow window movement without propagating a click?
I tried playing with the mouse down/up and min/max hold time settings but I couldn't find a "perfect" way.
The closest I can get is to have a combination of 3 triggers:
- keep middle click behavior: on mouse down, action "mouse click actions > middle click (at curr mouse pos)"
- hold to move window: on mouse down, after 0.05s, action "start moving windows"
- stop moving window: on mouse up, action "stop moving windows"
But the issue here is that it still dispatches a click so if my mouse is for example hovering a link on a webpage and I start holding the middle to move the browser window, it will dispatch a click on top of allowing me to move the window. I'd like to "not click" if the action is detected as a hold/drag...
Thanks for your help!
(Similar issue I have with achieving "mouse-only resize window" - as soon as I add triggers to the rightclick button, I lose its default behavior - if I could capture "drag" action apart from "single click", that would solve the issue!)
