When running script (javascript for automation) from file the program will leak memory. The process leaking is BetterTouchToolScriptRunner. There wont be leaks if the script is entered directly as "Enter Apple Script as Text". I was getting warning from mac and it had reached somewhere around 50GB memory (I've added a screenshot with ~10GB memory leak.
It should be noted my script run every .25 second.
The widget I'm using is "run applescript and show return value".
Macbook pro touch bar.
- Type of Mac: MacBook Pro (15-inch, 2016)
- macOS version: 10.13.6 (17G65)
- BetterTouchTool version: 2.645
Workaround: Write script directly instead of running from file.
