The maximize window to fullscreen function in BTT does not work properly with Premiere Pro CC 2018 or 2019 on my second monitor. It overhangs to my laptop monitor (my main monitor which is to the left of the second monitor) which cuts off some tools on the left hand side of the second monitor.
Happens when I use the built in Trackpad, Magic Trackpad and my bluetooth mouse (Logitech M585)
- Type of Mac: MacBook Pro (15-inch, 2017); 2.9 GHz Intel Core i7; 16 GB 2133 MHz LPDDR3; Radeon Pro 560 4096 MB; Intel HD Graphics 630 1536 MB
- macOS version: 10.13.4
- BetterTouchTool version: 3.080 (1187)
Tried updating and restarting before posting this; no luck. This has persisted through several updates.
