Maximize Window Commands not Working
Using Cmd + <-, Cmd + ->, Cmd + ^, Cmd + Down
MacOS Mojave 10.14 Beta, BTT v. 2.536
They are working fine here. Have you tried to restart your machine?
Is BTT allows in System Preferences => Security & Privacy => Privacy => Accessibility?
Yes, it is enabled in System Preferences, and it works with a mouse gesture.
My keyboard is set to US Dvorak if that makes any difference...
if you have recorded the shortcuts while dvorak was active then it shouldn't be a problem. Otherwise yes because BTT always binds to the physical position of the keys, not to their "meaning".
That's what I figured, but thought it was worth noting.
Here's a screen capture of the BTT settings.
These are for the "global" application.
