Note:
I am using an external keyboard and I have my command key which is mapping to the alt key so that when I press Cmd + Left Arrow, my mac can invoke Alt + Left Arrow which allows me to jump at the beginning of the word. So, if I press the keys in the order Cmd and then Left Arrow, it works fine but if I press Left Arrow and Cmd, it doesnt work. I checked this behavior with default Mac behavior and in that, the order doesnt matter. I am not sure if there is a easy way to configure this but based on the first visual, it seems like a bug to me rather than a custom feature.
Keyboard
As shown, I dont see any way to define the order or keep a trigger omnidirectional apart from the advanced condition (which makes sense as a work around, but I expect this as a default behavior as the Mac does this as default)
- Type of Mac: Macbook pro M1 2021
- macOS version: 15.6.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") 5.718
