BTT on M1 MBP with golden chaos default setup.
Crashes every time I press the Touch Bar shortcut for nightshift (this runs a script)
App restarts OK.
- Type of Mac: MBP M1
- macOS version: 11.01
3.508
I am seeing the same problem.
I am running BTT 3.540 (1679) with the GC-BTT settings (3.392).
Every time I try to toggle night shift, BTT crashes.
Below is the crash report.
Process: BetterTouchTool [50435]
Path: /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Identifier: com.hegenberg.BetterTouchTool
Version: 3.540 (1679)
Code Type: ARM-64 (Native)
Parent Process: ??? [1]
Responsible: BetterTouchTool [50435]
User ID: 501
Date/Time: 2021-01-25 23:36:31.459 +0100
OS Version: macOS 11.1 (20C69)
Report Version: 12
Anonymous UUID: 0E573198-9B69-4A32-4409-616CB45ABF83
Sleep/Wake UUID: F43DA2C1-CADA-4E12-89BF-453F2C404C99
Time Awake Since Boot: 11000 seconds
Time Since Wake: 3300 seconds
System Integrity Protection: enabled
Crashed Thread: 6 Dispatch queue: BacklightControl - Primary
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
night shift is currently not supported by BTT on M1 Macs (unfortunately the old technique to programmatically trigger it doesn’t work on m1 and I haven’t found a workaround yet)
