Thanks! That's exactly what I'm trying, I quit Karabiner but I still see some process running (karabiner_grabber, Karabiner-EventViewer, Karabiner-VirtualHIDDevice-Daemon, org.pqrs.Karabiner-DriverKit-VirtualHIDDevice). I'll try uninstalling and see if that makes a difference.
Edit: one more thing that's simply not working right now are the Fn-arrow key combinations for Page Up/Down, Home, End, or to change Backspace to Delete. I'll update here if uninstalling Karabiner fixes that as well.
I was looking forward to that feature as i got a new keyboard, and the right option and cmd keys switched places and now have a fn key between them (mx keys s).
I tried to switch them out, From Key: right_option, To Key: right_command, but it does not work. Now the right option key does not trigger anymore but the right cmd key doesnât do its job either.
I also tried a simple a > b remapping, but that didnât work either, not on the integrated Macbook PRO keyboard nor the USB one.
Any idea how i can debug that?
Cheers and thx for such a great tool, couldnât work without it and i am only using a fraction of its functionality ;p
p.s.: in the Current Keyboards dropdown, when i select my current keyboard, it just blinks the name once and then the field is empty again.
I think I might not understand, the low level key remap feature can only remap single keys, so remapping combinations like fn+ arrow won't work with that (use BTT's standard keyboard shortcut feature for such). Or did I misunderstand?
I mean the standard Fn key combinations on Mac OS (Fn+Up Arrow = Page Up, Fn+Left Arrow = Home, Fn+Backspace = Delete, etc.) I expected that remapping Right Command to âstandard globe / fn / function as modifierâ would allow me to trigger those.
ah yes, that works. There are however multiple types of FN keys available in the remapping list - it only works with one of them as far as I know. I'm currently not on my Mac, can check tomorrow!
Thanks! I havenât been able to make it work (Iâm now using a fresh config), and the issue of not being able to retrigger custom shortcuts (e.g. Fn + O to show/hide Safari) remains: I need to release the remapped key before I can trigger the shortcut again.
Please let me know what you can find.
Edit: maybe another option for me is to just not remap right command to fn at all, and just change all my Fn mappings to use right command (e.g. Right Cmd + O to show/hide Safari) and simply recreate those Mac OS defaults (Right Cmd+Up Arrow = Page Up, etc.) I just highlight the current situation because it almost works perfectly for me, and Iâm used to mapping Fn+ to show/hide my most used apps.
Iâm also finding the mapping is unresponsive. However, I do acknowledge that I likely misunderstood the implementation of, âThe predefined action "Remap Keyboard Key (Low Level)", especially when accompanied with the below image in the initial post.
@eli5 what are you trying to achieve? and which version of BTT / macOS are you running?
//edit: ah I just saw 12.7.6 - this feature probably doesn't work on this old macOS version (the APIS where available but broken and I think Apple never fixed them on these versions). AFAIK it requires at least macOS 15
@Andreas_Hegenberg I tried remapping Caps Lock to Fn. It works as expected when pressed on its own (it shows the Emoji picker) as well as when using it to trigger another BTT action that has Fn + Ctrl + A as its trigger. However, it doesnât work with my trigger Fn + Ctrl + Up Arrow. When recording a new trigger, Fn + Ctrl + A (using CL as Fn) is correctly recognised, but Fn + Ctrl + Up Arrow is recognised as just Ctrl + Up Arrow. Do you happen to know whatâs the problem there?
I also noticed that the same behaviour occurs when Caps Lock is remapped to Fn using the System Settings.
the problem is that the arrow key implicitly already contains the function key modifier on macOS, however it should still work - it will then record like this:
Oddly, if I remap CL to Fn for all keyboards (by leaving the optional field empty), on the internal keyboard of the MacBook CL + Arrow works like and is recorded as Fn + Arrow (as you say), but on my external keyboard (where the default FN key is not passed to the OS) CL + Arrow is recorded only as the arrow key.
I noticed that the âHomeâ, âEndâ, âPage Upâ and âPage Downâ on my external keyboard work the same as Fn + "Left Arrowâ, âRight Arrowâ, âUp Arrowâ, âLeft Arrowâ, respectively. So Ctrl + Fn + Up Arrow on my internal keyboard is the same as Ctrl + Page Up on my external keyboard. Thatâs quite unintuitive, but very good to know. Now I can continue using my existing triggers on my external keyboard without having to reassign them.
@Andreas_Hegenberg just wanted to reach out again and confirm that remapping a key to âstandard globe / fn / function as modifierâ does work with built-in MacOS combinations (Page Up, Delete, etc.) What Iâm still seeing is that if I map Fn+ to a BTT action, and then I trigger that action, then BTT behaves as if I had released Fn, even if I havenât, so I can only trigger a single action while holding the modifier.
