I have set up the same shortcut (long/short press) to start two different apps. But BTT just shows me a conflict menu where I can choose between the two apps.
What am I doing wrong?
short 0 sec, long 1 sec
I just pushed a little extension in alpha 3.766.
To setup a shortcut that triggers one function on short press, and another on long press do it like this:
Long Press:
Short Press:
Works, thank you!
I need to change it one more time - in the 3.767 alpha the maximum hold time will reset to zero, you'll need to set it again.
No problem, I wait
