The long press left click actually works well. So far I have discovered only one "problem". If it is used in a text app, let's say for Mission Control, then when you return to the text app you will find highlighted text. Not a big deal, just to let you know.
Ah, I think I understand now. While the Mission Control windows open with an upward movement, the pressed left button acts as if something is selected.
