Under the "Normal Mouse" tab in BTT, I set some shortcuts based on my Logitech G403 Hero mouse, and they are not working.
They DID work for a few days but they randomly stopped working. I'm not sure why. I have the logitech g-hub software set with all default settings and nothing overriding BTT, still broken. I even tried fulling uninstalling logitech g-hub and restarting but it still did not fix.
SOME of the shortcuts work (side buttons used for fwd/back page), but the broken ones are custom scroll-wheel events (holding CMD or Option while scrolling up or down). Any idea how to get these fixed? I'm at wits end
- Type of Mac:
- macOS version:
