Hello!
I love to see the work on logitech mice. I have a Logitech G600, it has 12 buttons on the side, 2 extra on top and a shift-like modifier allowing you to essentially have 28 usable extra buttons.
I’ve been using hacky workarounds like using F14-F20 re-mappings to make things work in the past, but would love to have native BTT integration instead.
I tried the new build 5.800, but when I try to configure Logitech Mouse Configuration, it says “No Supported Mouse Recognized”.
Any ideas how to fix, is the G600 supported yet?
- OSX 15.7.2
- Mac Mini
- Intel
- Afaik I don’t have Logitech installed. I did however do hardware based configs on the mouse (hard-ware re-map of side buttons).
- I’m a software engineer at Amazon, iTerm savvy/Technical. Happy to provide any useful technical outputs/logs. I have 2 G600 mice, one work as well as at home.
Happy to buy & ship you a Logitech G600 if it helps with development efforts
. (Or send you equivalent Amazon gift card/donation).
