Logitec Mouse - missing clicks
I'm using BTT 6.743 and a Logitec MX3s with the latest offline version of LogiOptions+ installed.
Since a few weeks i'm noticing that sometimes mouseclicks are missed. I need to press 2-3 times until it works. If i stopp btt it's all fine.
I tried setting "high level mouse events" on or off and played with the settings. But not sure if it's improving. MAYBE it got a little better with Max Quick Release time 0.2 -> 0.3
Any advices?
Do you have any mouse triggers configured in BTT? (The settings you mentioned do not have any impact if you don't have mouse triggers configured in BTT)
Do you know you can get rid of LogitechOptions+ if you have BTT running? While there are no known conflicts between them it would still reduce resource usage on your machine. Logitech Mouse Support | BetterTouchTool Documentation
i tried getting rid of logitoptions some month ago, but there were issues - can't remember wich ones exactly anymore - so i switched back using it .
i have some mouse triggers configured.
Any suggestions how i could find out whats causing the missing mouseclicks?
You could try looking at the recently used section in BTT to see whether any of your mouse triggers is listed there when missing clicks have happened.
Alternatively, if you encounter missing clicks go to Help => Export Basic Debug Logs and send them to andreas@folivora.ai, then I can check whether anything is blocking clicks.
